FPGA with HDL node
I am using a PCI-7831R. I have a VI that is basically putting out data into a board that we aare devoloping. I also have a HDL node as another VI that looks at frames sent out from another board and picks out words from certain locations in the frames. I want to know if I can run this HDL node VI along with the other VI. Thanks
Bibin
(3,086 Views)
Hello Bibin,
You should be able to run both VIs at the same time if you place them in parallel inside a bigger Main VI.  So, both VIs will be running as subVIs.
The only restriction would be if they were talking to the same IO channels.
Hope this helps.
Ricardo S.
(3,077 Views)
