09-22-2025 01:44 PM
Hi everyone,
I’m using the NI PCI-6528 card, which supports both Single-Ended (SE) and Differential (DI) digital input configurations.
Can someone help me understand why the single-ended configuration isn’t working? Am I missing something in the wiring or configuration?
Thanks in advance!
09-22-2025 08:12 PM
The DI− pin is not just a reference — it’s part of the current loop for the opto-isolator. Even in SE mode, you must provide a return path through DI− for current to flow and activate the input.
You must still connect DI− to ground to complete current loop.
10-03-2025 06:19 AM
Thanks for the reply. I will check the Hardware configuration
