Fast Analog and Digital sampling
I am using Visual Studio.Net 2005 and DAQmx 8.3 to interface with the device USB-6008.
The analog line represents two signals, I know which of them is currently active by reading the digital line, and I need to store them both.
The data logging works fine apart from the slow speed, I am getting about 30 samples per second.
I am doing the following to obtain the data:
    while ((i < MAXSAMPLES) && (DIData[0] == DigitalReader.ReadSingleSampleMultiLine()[0]))
        AIData[ord(DIData[0]), i] = AnalogReader.ReadSingleSample()[0];
        i++;
Is there a faster way to acquire the data?
Ariel.
(3,954 Views)
Hi Ariel,
The way that you are currently acquiring the analog data with the ReadSingleSample method in a loop is entirely software timed.  The speed at which your PC can execute the read function is causing the limitation of 30 samples per second.  If you need a faster sampling rate I recommend setting up a hardware timed acquisition so that the internal timebase of the USB-6008 is used.  For your application you could continuously acquire data from the channel.  Depending on the state of the digital line, you could read the data to a different array or file.  I would recommend starting with one of the shipping examples for continuous acquisition located in the following directory:  C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNET2.0\Analog In\Measure Voltage\ContAcqVoltageSamples_IntClk.
Andrew W
(3,928 Views)
Thanks for the reply,
The problem is that the digital line changes every approximately 50ms.
* If I’ll do the same for the Digital line, logging them both in parallel, are they going to be kept in sync?
This way I can sort the data on the PC.
* Or is there a way to configure the device to start logging the data on falling and stop on raising (and visversa)?
The closest thing I could find is AcqVoltageSamples_IntClkDigRef but it shows only how to start the sampling
* Or in case you have a better suggestion please let me know.
Ariel.
Message Edited by tanffn on 06-03-2007 01:45 AM
(3,899 Views)
I’ve resolved the problem by sampling the digital input in an analog input (option 1), as the digital line has only static sampling..
Thnaks for the help,
Ariel.
(3,889 Views)
