Fast controlling with LabViewRT analog I/O
I`m using LabViewRT with the PCI 7030/6040E DAQ-Board.
I implemented a controll circuit but the fastest scan time I got for the analog I/O was only 1.5 milliseconds.
Does anyone know how to improve this scan times?
And does anyone know the fastest scan time for this card?
(2,651 Views)
The 7030 is only capable of control loop rates of approximately 1 kHz for a single channel. If you require faster loop times, you might consider a PXI controller with a PXI DAQ device. Our fastest PXI controller is capable of over 40 kHz.
If you are simply looking to get a little more speed out of things (like shaving that 1.5 ms down closer to 1 ms [inverse of 1 kHz]), you might try viewing some of the documents at the following link:
NI Developer Zone : LabVIEW Real-Time : Timing Loops and Optimizing Performance
(2,651 Views)
