Faulty readins when input voltage is above 1.1 VDC
i have a NI USB 6351 multifunction DAQ unit that has been working fine up uintil today.  Now I am getting strange behavior. Wondering if anyone has any ideas what could be up.
I am using the Measurement and Automation explorer Test Panels to look at analog input samples.  Input is configured for -10 to +10, Differnetial signaling.
My input is coming from a DC power supply.  Readings look good when the input voltage is below about 1.1 volts DC.  When I increase the voltage to about 1.2 VDC, the readings begin to jump to +10.5 (or so) and back to the correct value.  If I continue to increas the input to around 1.4 VDC, the reading jumps to about +10.5 and stays there.
Any Ideas what may be causing this behavior?
(4,184 Views)
Does this occur on all channels?  Have you tried using internal channels to verify the operation of the ADC?
Cody A.
(4,143 Views)
