Filter enabling of multifunction NI-DAQ(USB-6229)
How can I enable the input analog filter of a Mutifuntion NI-DAQ USB-6229?
I use LabVIEW 8.5 and NI-DAQmx 4.3.
Thanks in advance
(2,834 Views)
Hi Ramin-MSU,
Thanks for the post and I hope your well today.
I am afraid you don't have an analog filter on the USB 6229.
The High Accuracy M Series (628x) boards have a built in programmable filters. If you look at the product specification for the 6229.
http://www.ni.com/pdf/manuals/371290g.pdf
Analog input doesnt mention filters.
But if you look at the specification for the 628x, it does.
http://www.ni.com/pdf/manuals/371292f.pdf
However, if by chance you do have a 628x - you can find out how to use it here:
Programmable Filter on M Series Boards
http://digital.ni.com/public.nsf/allkb/AAB391A5A08BD72D86256F9C006B039E?OpenDocument
Hope this helps to clear this issue up.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,820 Views)
