Filter out Device Noise
I am using the NI USB_6001 DAQ. By wiring the DAQ to itself (AI 0+ & AI 4-) and running a differential measurement on the device itself, I am getting a noise reading that switches between  -0.0002 V and -0.0015 V (picture attached). Resulting in -1.3 mV noise being in the device alone. When trying to get a reading of 5V from a power supply I am getting readings that switch between 4.9891 V and 4.9879 V (picture attached). Again that ~1.3 mV switching.
Is there a way to measure the device noise and filter it out from the voltage read?
I am trying to read as close to a flat DC line as possible.
Is there a way, perhaps in LabView, to set up something that will measure the internal noise by wiring a short wire from pins AI 3 and AI 7, running a differential measurement on those pins to get the device noise with no voltage being supplied. And then to read pins AI 0 and AI 4 and subtract the device noise from the results of the voltage read?
I have read the Field Wiring and Noise Considerations for Analog Signals a couple of times and already aware that I am using a Grounded signal source (power supply) and a differential measuring system (DAQ). I know that this can cause a Ground-loop noise to be present. I have tried numerous different wires and different wire lengths with no change. I also am aware that there is some miniscule noise variation when my laptop charger is plugged in vs not plugged in.
Any insight would be greatly appreciated.
(2,124 Views)
Your device supports only a 20V range from -10 to +10 VDC.  It digitizes with 14 bits.  20V / (2^14) ~= 0.0012 V.
What you're seeing is 1 bit worth of quantization noise in the LSB of your A/D conversion.  I don't know if you're gonna be able to do better than that.
If I *had* to try, I'd oversample and average.   The theory is that as the LSB toggles back and forth, a mean will weight the two values proportionally to the time spent at each.
-Kevin P
(2,099 Views)
