Find PXI-6683H Device Name
I would like to programmatically detect if my chassis has a PXI-6683H connected to it.  I tried using a DAQmx System Property Node set to read the Device Names property.  It finds all of my PXI-6133 cards, but this method does not list the PXI-6683H for some reason.
Is there some way to programmatically detect in the block diagram of my VI if I have a PXI-6683H connected to my chassis, and if so, retrieve its name?
(3,706 Views)
Check this other thread that talks about a similar question of yours.
Luis G.
(3,682 Views)
