Find intersampling time between two AI channels USB 6251
I am trying to find out how much delay there is between samplings of two AI channels in a USB 6251 (Mass Term) used in conjunction with a SCB-68 connector block (Labview 8.5, Windows XP).  I realize that there is only one ADC and simultaneous acquisition is not available.  The specs are listed as follows:
Sampling Rate:
Maximum:  1.25 MS/s single channel;  1.00 MS/s multi-channel (aggregate)
Minimum: No minimum
Timing accuracy: 50 ppm of sample rate
Timing resolution: 50 ns
Does any one know of a way to figure this out other than through experimentation?
Message Edited by usf on 05-29-2009 07:13 PM
(3,036 Views)
Accepted by topic author DanceWiz
See this
(3,025 Views)
Dear Dennis,
Thanks for your prompt and accurate answer.
(2,999 Views)
