Fixing error-10452-'No Interupt level avaible for use' for AI on Lab-PC-1200
All I am trying to accomplish is to read multiple analog inputs at the same time. All that is needed to do to reproduce the problem is to run the VI. The AI config works fine with no errors, then the AI start produces the error and that carries through. The steps I have taken to solve the problems is to use the more basic analog input scemes such as AI mult pt and such, but I would like to use something with more options, such as triggering and etc. Labview 6.0 is the only software I am using. The error message that is produced is: error -10452, 'No interupt level availble for use'. Also, the VI that I am using was created by the DAQ assistant, so I did not write it. I was planing on usin
g that as a starting point.
(2,648 Views)
I have had the same problem yesterday (-10452), i changed in the BIOS the configuration of the parallel port to EPP and i asigned the IRQ 7 to this port. Try to do it...
(2,648 Views)
