‎05-01-2016 12:58 PM
There you go 🙂
‎05-01-2016 07:00 PM
Is the area marked in this image what you are calling a jump?
What I think I am seeing there is an aliased high frequency signal. It is ~ 20 mV, not 2-3 mV. What is your sampling rate? What is the duration of the signal shown in the Input Voltage A image?
Lynn
‎05-02-2016 04:26 AM
Hi Lynn,
The Sampling frequency is variable, depending on the input frequency of the singal, and varies from about 150 Hz (at low frequencies) to 15kHz (at higher frequencies).
The graphs were for 0.05Hz, I think, and the duration accordingly was about 20 secs (1 cycle).
Cheers
Sid
