Force use as traditional (legacy) DAQ instead of DAQmx
I am using several PXI DAQ devices that, upon install of all the drivers and associated NI software, are recognized as DAQmx in the Measurement & Automation Explorer. However, the application that I wish to use these devices in requires that they be recognized as traditional (legacy) DAQ devices (not DAQmx) for the existing code to work properly. I have installed the traditional DAQ drivers (version 7.50 - beta) alongside the DAQmx drivers but have not yet been able to get my devices to be recognized as legacy.
How can I force the devices to be recognized as traditional (legacy) DAQ instead of DAQmx?
I do not need to use DAQmx for my application. Can I selectively uninstall DAQmx and keep the traditional DAQ drivers.
I am confident that the combination of hardware, drivers, and my OS will work together correctly since, at one point, I did have it set up properly.
(3,522 Views)
What operating system are you using?  The Traditional NI-DAQ 7.5 beta should only be used on Windows Vista.  There is a known issue with the Traditional NI-DAQ 7.5 beta on any OS that will result in being unable to use devices with Traditional NI-DAQ if NI-DAQmx is installed.  There are no plans to release an updated beta version and no known workaround.  We strongly encourage anyone using the Traditional NI-DAQ beta driver to develop and test NI-DAQmx code on a separate machine and to replace the Traditional NI-DAQ code as soon as possible.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,520 Views)
I am using Windows 7 (32 bit).  Although it is not officially supported, through great effort, I was able to get it working once before.  But I have been unable to recreate that success. I think it might have required careful installation so as not to install the mx drivers and only installation the traditional drivers.
Are you saying that if I was using Windows Vista, it would automatically recognize these devices as traditional instead of mx?
(3,514 Views)
The issue exists for both Vista and Seven.  Some machines may be able to use both side-by-side, others won't.  We haven't really seen a pattern as to which machines are affected.  The best policy when using the Beta driver is to not install NI-DAQmx along side the beta Traditional NI-DAQ driver, regardless of OS.
Seth B.
(3,512 Views)
I was able to selectively uninstall just the DAQmx drivers, and then install only the traditional drivers.  In doing so, my DAQ devices were properly recognized.  However, there was still a mysterious problem of one of the cards not functioning correctly unless I swapped it with another card in a different slot.  Then Windows saw it and installed it (so say the notification balloon the popped up), and then everything worked fine.
(3,501 Views)
