Freeze and Frequency Analysis
Hey Alex,
I still have just a straight line. Its like my MEMS gets no data, but i made a test in the DAQmx and the hardware works fine. I added some screenshots. You have any idea? 😞
The error message is also strange because i setted everywhere the same rate(1kHz) and samples(100) like ago. Or did i missed it somewhere?
Thank you very much!
Message 21 of 42
(2,534 Views)
Hello Gregory88,
disable the highlight mode
best regards
Alexander
Message 22 of 42
(2,532 Views)
no change 😞 just a straight line at -5 volts-5V.jpg!?!?!?
Message 23 of 42
(2,526 Views)
Accepted by topic author Gregory88
Alex... i think i know why.. is it because i have changed the DAQ card? last week i used the SCB 68a with a PCI card. Now its a USB 6001 from NI
Message 24 of 42
(2,521 Views)
Thank you very much for your help and your patience! It works FFT.jpgSome last questions:
For understanding: 1. why makes the FFT in the first milliseconds always this one big peak?
2. the amplitude in the FFT is in Herz?
For the program:
3. could it also be possible to vary the waveform graph 2 and 3 from 10 seconds manualy into 15 or 20 seconds? e.g. through a rotary knob?
Message 25 of 42
(2,506 Views)
Hello Gregory88,
1. This could be the dc part in your signal.
2. What are the Output Units of FFT-based VIs?
3. Attached
best regards
Alexander
Message 26 of 42
(2,498 Views)
Hi Alex,
thank you it´s also a nice feature, it´s great thou, but i would like to scale the x-axis and maybe y-axis by a rotary knob.
Furthermore i tried to write the data from the "waveform 2" & "waveform fft2" into a excel chart to print and compare them. Attached my VI with Express tools Smiley Embarassed does´nt work as expected 😕
Message 27 of 42
(2,496 Views)
Hello Gregory88,
How Do I Programmatically Format the X-Axis of a LabVIEW Graph to Display Timestamps?
With this way you can set also the minimum and the maximum for each axis.
There is also a method export grap to excel
Daten von NI LabVIEW nach Microsoft Excel übertragen
Save to a series of files and use the true to generate a new one.
best regards
Alexander
Message 28 of 42
(2,480 Views)
Hi Alex,
the scale with the x and y axis doesnt work, just the description changes the graph stays constant. 😕
An "extra" idea for my VI is to create sth like a RMS - all three voltage signals (x-y-z-axis from the analog sensor) could combine together and could be visual in an extra waveform. would be usefull that i dont have to switch between the 3 signals of the sensor and compare everyone after each measurement.
attached the VI
Message 29 of 42
(2,458 Views)
Hello Gregory88,
like this
for the scaling the range maximum property can be used.
best regards
Alexander
Message 30 of 42
(2,451 Views)
