Functionality of DAQ
Dear All
I wants to know how the DAQ card works. Like how the analog output , DO signals are generated. How DAQ captures the data.And when we changes the Sampling rate or number of samples etc., these changes internally effect which part of the DAQ card. How the counter generates the pulses.
If anyone is having any document releated to this then please share the document.
Thanks & Regards
J
(2,911 Views)
Hi J,
Thank you for posting to the NI forums.
Which DAQ device are you using?  Assuming that you are using an E-Series (60xx) or an M-Series (62xx) device, I have placed the user manual for these product families below.
E Series User Manual
M Series User Manual
These manuals have detailed information about the theories of peration oof the internal workings of these devices.  In addition, check out the following tutorial describing common DAQmx function calls.
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
Hopefully these resources will help you get started with your DAQ application.  Please post back if you have more specific information related to your device, or if you have any further questions.  Have a great day!
Ed W.
(2,881 Views)
