07-27-2008 03:39 AM
Hi
I am doing a fairly simple port, converting software originally written for a NI6601 in Legacy NIDAQ to a USB 6210 in NIDAQmx. I am using the TwoEdgeSeparation task but I am having a problem finding an alternative to the GPCTR_Watch which I originally used to display progress to the operator. So originally I could tell from the counter contents if the counter had started (start pulse has arrived) . Detecting the arrival of the stop or timeout seems easy enough by checking that the task has finished.It's detecting the start pulse ( which can be too short to detect by a simple digital read) which is giving me a problem. Any ideas?
Regards
Martyn Eccles
08-04-2008 03:34 AM
02-02-2009 04:55 AM
Hi Rich,
I'm just coming back to look at another application similar to the previous one. Can you tell me if this problem has now been solved on the latest mx version?
best regards
Martyn
