Gaussian Signal Generation using DAQ USB-6363
Figure1: Excitation signal and Received Signal from journalsFigure1: Excitation signal and Received Signal from journalsFigure 2: Frontpanel and Block diagramFigure 2: Frontpanel and Block diagram
I want to generate a Gaussian pulse (center frequency around 100 kHz) to actuate Piezo1 (PZT1) and signals to be acquired from Piezo2 (PZT2).
Signal generation (Analog Output) using Simulate signal block with gaussian noise added is to actuate PZT1 with separate loop through DAQ assistant.
Signal acquired through DAQ Assistant (Analog Input) from PZT2 are done with separate loop.
How to acquire this type of signal attached in Figure 1.
How to solve the error shown in Figure 2.
Message 1 of 1
(1,168 Views)
