Generate series digital output
Hi, all,
I am using USB6259 DAQ and trying to generate some series digital output in a single digital IO line.
The idea is that I can first type in some digital numbers ,e.g. 110001. And then this digital pattern is generated in a single digital IO line, with either internal or external clock.
Since I am not familiar with DAQ and I searched the examples in the Labview. However it seems that I didn't find useful information.
Can anyone give me some hint?
Thanks a lot in advance.
(2,946 Views)
Hello Rui0632,
Are you familiar with LabVIEW?
Have you taken any courses about it?
Are you familiar with design patterns used in LabVIEW?
The following example (Cont Write Dig Port-Ext Clk.vi) already should give you an idea on how to send a pattern with your card.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,927 Views)
