Generate two independent signal and a pulse train with NI USB-6259
Hi all,
I am new to the forum, I have searched but I have not found any info about it.
I have recently implemented a vi which is capable to generate from a NI USB-6259 two signals which are different in frequency, amplitude and phase (see attachment).
In order to do that at each cycle the buffer size is changed accordingly to the frequencies in order to see an integer number of periods and, thus, not having leakage in generation (or jumps).
Now, I would like to generate a pulse train with a frequency which is an integer multiple of the frequency of the input signal (not the 50Hz one).
The resulting frequency of the pulse train could be changed on the fly (or at least being updated at each new cycle of the vi).
I am stuck because I have already declared two analog output channels and I want the pulse train to be a digital output for my board (channel PFI), have you got any ideas?
many thanks
Alberto
PS. The vi is "programma generazione.vi" but you firstly need to install "generating signal.vi"
(3,950 Views)
Accepted by topic author albertocarboni
this is a simple .vi that generates a buffered pulse train, dinamically configurable. I want also let you know that with this type of boards (DAQ) it's impossible to update output in Real-Time. You've to be careful because the time between you use "DAQmx Write" and the effective phisical output change IS NOT FIXED.
Matteo
(3,870 Views)
