Generating -5V ; 0V ; 5V at 200kS/s
Hi!
I need to generate 3 voltage levels (-5V ; 0V ; 5V) on 32 outputs at a speed of 200kS/s on each output.
The best would be to use a FPGA card, so I could re-use it in the future for other application but the difficulty is to generate the -5V. All DACs I've seen aren't fast enough to meet my requirements...
Which card would you choose ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(4,556 Views)
You could use an FPGA analog output, but you would need four FPGA cards since each only has 8 AOs.  There are some AO waveform boards that comoe close to what you want, but they can only do 180 kHz with 8 channels, and you would still need 4 boards.  These are both fairly expensive solutions.
I wonder how difficult it would be to build a custom circuit to sum or combine two digital signals to get your desired outputs.  You could get the different levels by turning on 0, 1, or 2 digital signals, and it would use a total of 64 DOs.  I'm no expert on building circuits, but it seems like this would be a fairly simple circuit to build.  You could create the signals using either a digital FPGA or a high speed digital board, which is fairly cheap.
Bruce
Bruce Ammons
Ammons Engineering
(4,534 Views)
Hello!
You should phone to the NI commercial service.
They will advice on the choice of your board.
Regards.
Romain D.
National Instruments France
(3,198 Views)
