Generating DC voltage in synchronization with digital waveform
Dear all,
                 I am trying to generate an analog voltage output (DC voltage in steps of 0.1V), simultaneously i need to trigger a firewire camera to acquire image. At the beginning of every frame, the DC voltage increases to a new value from 0.1V to 0.2V in the second interation and so on...
I am stuck now on generating a finite sample DC voltage with continuous digital waveform. I can not think of running both of them in different loops or one while loop (for digital waveform) and on for loop (for DC generation).
I need to generate both of them from same USB PCI 6259. By the way i am using counter pulse for triggering these two tasks for sync.
Any help would be appreciated. See the attached  images for front panel and block diagram.
Regards
Visu
(2,890 Views)
Here is the vi which i have used for generating DC voltage simultaneously digital waveform. PWM is a sub vi used for creating digital waveform.
(2,877 Views)
