Generating a timed DC voltage
Dear all,
               I would like to generate a DC voltage to drive a PZT actuator to move a mirror few microns, but need to increase voltage for every 40ms (say initially 1V after 40ms would like to generate 2V) . I came across an example of generating analog DC voltage. I have attached here the example vi.
Please kindly help me. Thanks in advance.
Visu
(3,065 Views)
Hello Visu,
If you have a pre-defined set of values that you need to output, you can just define an array and write on a for loop timed for 40 ms on each iteration. If you are going to drive it on demand, you just need a while loop and change a numeric control.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(3,047 Views)
