Generating multiple ramp pattern
hi Peter, thanks for response.
I've managed to make a program which generate multiple ramps using 1 task (in my other thread). But my next challenge is, can I generate these ramps and another sinus wave using 1 DAQ card? Maybe the idea is to make the same amount of samples for the ramps and sinus wave.
regards,
Yan.
Message 11 of 13
(1,451 Views)
Hi Yan!
You are correct. It will be the same process as before , but just add a Instead of using that Ramp VI, you can change it out for a Sine Pattern VI. It will also need to have the same amount of samples between the two.
I also would like reiterate that your other forum thread has more visibility than this thread. I would suggest keeping any additional questions you may have on that thread. I will keep a watch on that thread to be sure that your questions don't go unanswered.
Have a great day!
Peter E
Message 12 of 13
(1,440 Views)
hi peter,
I'm having a new problem and I posted it in my thread, you might be able to help?
regards,
Yan.
Message 13 of 13
(1,425 Views)
