Generating signals with NI USB-6251 using Visual Studio
I am trying to generate a sine wave using Microsoft Visual Studio 2010 with NI USB-6251. Sample codes coming with the download does not work with this device but it does work with the PCI-6025. Using Measurement&Automation Explorer I checked that the device is working properly. Do I need to change something to make the same code work with the USB connected DAQ?
Thanks for your interest.
(3,060 Views)
Hi Buket,
Which sample code are you using? Do you receive an error message when trying to use with the USB-6251?
Jackie B
DAQ Product Marketing Engineer
(3,050 Views)
