I am trying to get a digital IO line to trigger waveform generation. I have a function call that invokes WFM_Op(), which is set up to trigger on one of the PFI inputs. This part works fine for an externally generated interrupt.
What I want to do is use one of my digital output lines, looped back to the PFI input, as the signal source. However when the call is made to the DIG_Out_Line() it hangs, it seems like it's waiting on the call to WFM_Op() to finish first. (Obviously my program is multithreaded)
It seems pretty weird that you wouldn't be able to do this, the two things should be separate.
Anyway if you have any suggestions or another method to attempt that's more to your liking please let me know.
Stefan
Tarrant
Research Engineer
C-CORE
Captain Robert A. Bartlett Building
Morrisey Drive
St. John's, NF
Canada A1B 3X5
Tel: (709) 737-8372
Fax: (709) 737-4706
E-mail: Stefan.Tarrant@c-core.ca
Web site: http://www.c-core.ca
This communication (including all attachments) is intended solely for the use of the person or persons to whom it is addressed and should be treated as a confidential C-CORE communication. If you are not the intended recipient, any use, distribution, printing, or copying of this email is strictly prohibited. If you received this email in error, please immediately delete it from your system and notify the originator. Your cooperation is appreciated.
