Getting a jump from input voltage reading to 10v, then it drops back down and again jumps to 10v.
There is a 1.5v analogue input into the DAQ card. However when I am examining the signal on the waveform graph in labview the signal jumps from 1.5v to 10v and back down again.
The jump from 1.5v to 10v seems to be periodic.How do I get the signal to stop oscillating from the real voltage to 10v.
(2,711 Views)
Hi Moon,
This sounds like you might have a ground problem. Are you sure all your connections are secure. Also could you tell me what type of DAQ card you are using and what driver version you have.
(2,692 Views)
