Giving signal to AO as command signal to the controller
My application labview is, using 2 Analog input signals (A & B) and subtracting (A-B) signal and using this signal as command line signal to Analog Output channel, which in-turn is connected to external relief valve controller which opens proportinally to the signal received at Analog Output channel.
I'm using PCI6259 & PCI6711 as hardware for my application.
I was checking for the same in examples, but couldn't get that.
Thanks in advance for the follow up
-Kirit
(3,269 Views)
Hi Kirit,
Search for the following examples in LabVIEW:
Input - Acq&Graph Voltage-Int Clk.vi
Output - Cont Gen Voltage Wfm-Int Clk.vi
Combine both the VIs into one and do the required modifications.
Hope this helps.
Ujjval Shah
(3,247 Views)
Thanks Ujjval,
I have made that logic, even then i will look into the VI's suggested by you for any improvement that i can make on the logic i made....
Will get back to you after trying out
Regards
Kirit
(3,244 Views)
