Global variable reliability
I am using a Global variable to transfer data from one VI to other. In one VI, I am writing to the global variable contineously.
And in the second VI, I am reading this global variable and writing it in a text file. Both the processes ( writing to and reading from GV) occur simultaneously. I have tested the software for 24 hours and I had no problems like race condition.
My question is, I have to run this software non-stop for 180 days for permanant monitoring and logging.
I want to know if the Global variable approach is reliable in my case?
regards,
Swap
(5,256 Views)
Your question has nothing to do with multifunction daq. You should have posted to the LabVIEW board.
You would be better off with a producer/consumer design where you pass values to the second loop via a queue. You are liable to either skip values or get duplicate values when you read the global.
(5,253 Views)
sorry, posted here by mistake.........anyways thanks for the reply.
(5,249 Views)
Pet peeve of mine.
I inherited a VI much like what you are describing.  It somehow worked on a test system for many many years.  Then there was a computer upgrade and suddenly only 1/4 of the data was logged.  Race conditions.
Luckily, I was already changing that VI to use Queues and then it worked perfectly and didn't burn up the CPU nearly as much.
Look into the Producer/Consumer.  That is what you really need to do.
(5,241 Views)
Hi Crossrulz,
I have never used producer/consumer loop. I have looked into the producer/consumer example but it was to transfer data between two
different loops in the same VI.
In my case, I have two different VI's (not SubVI). Could you please give me an example of how to do it using producer/consumer loop
for two different VI's ?
I would appreciate if you could help me.
Thanks in advance.
regards,
swap
(5,239 Views)
You just need to pass the queue reference into your two VIs.
(5,237 Views)
