Hardware suggestion for large number of Thermistor measurement
A project requires me to carry out temperature measurement at 100 points using thermistor sensor. I am planning to use cDAQ 9178 chassis and some Analog input modules. The measurement points and PC are around 30 meter away. So I will try using USB extender to transmit measurement signal this far.
I need suggestions regarding C-series modules that can be used for thermistor measurement. Kindly also comment on my scheme. I am not sure if using USB extender will work. I need to get one scan per second speed.
Thanks in advance.
Message 1 of 1
(2,198 Views)
