Has anyone found a source for high temperature cables for 6259
Need a 6259 and 6552 cards to control DUT in a temperature controlled chamber. Would like to go as high as 100degC. Anyone know where I would get NI compatible cables that can be used fed into the chamber?
(2,875 Views)
What are the ends of the cables going to be connected to? What form factor are the cards (PCI, USB, PXI, etc)?
-AK2DM
(2,865 Views)
AK2DM, thanx for your reply. The ends of the cable would be connected to a PCB with a DUT mounted (the DUT would be an IC). PCB would be mainly passive with small amount of active circuits. I would want to plug directly onto the PCB because multiple 68 pin connectors would be needed for the testing. The setup is like a HTOL (Burn-in) arrangement for an IC.  The driving cards would be from a PXIe 6259 and also a 6552.
(2,847 Views)
