Has anyone succesfully used NI-DAQMX 8.0 on SLES 10?
I'm looking to purchase the PCI-6259 board.  According to NI's driver support table, NI-DAQMX-8.0 is fully supported on SUSE 9.3, possibly supported on 10.0,10.1,10.2,10.3.  From what I've gleaned from this page,  it is the OpenSource version of SUSE and not the Enterprise version that is supported.  Our application currently requires the Enterprise version.  Has anyone succesfully run the this driver under SLES10?  I am researching the kernel differences now, but I'm hoping SLES 10 is compatible with one of the OpenSource versions.  As a follow up question, has anyone been successfull using DAQmx-8.0 on OpenSource versions 10.0 and above?
Kevin
Message Edited by kacox on 02-09-2009 01:33 PM
(3,290 Views)
There are a couple of related threads on trying to get this installed on unsupported versions of Linux. You can check them out here and here.
Chris W
(3,270 Views)
Chris
Thanks for the info.  I was successful loading the drivers after following the steps in the first link.  When I get the card I will verify that it works.  For others looking at this thread, make sure you are using the 32 bit version of SLES 10.
Kevin
(3,262 Views)
