Having problem with discontinuity in the waveform
Hi Experts,
I am trying to build a multifunction vi that is able to generate analog waveforms and read them simultaneously using USB-6251 and Signal Conditioning Connector Block Model SC-2345. I plan to add a signal from the sensor to the waveform in the future but that is not the case now. However, when I run the program, it turns out to a small discontinuity in the waveforms which I really have no idea how to fix it. And it is quite unacceptable since it affects the shape of the waveform and its frequency. I attached the file. Any suggestions would be greatly appreciated.
Sorry if my English causes you problems. Thanks in Advance.
Nattapat Thanesvorakul
Student
(3,631 Views)
Please... anybody....
(3,595 Views)
duplicate post
You need to learn a little patience. Most of us here are volunteers. Do NOT ask the same question in multiple boards.
(3,585 Views)
It would be better if you can post a screen shot of the discontinuity.
(3,576 Views)
Search the forum for spikes, glitches
Maybe this solves the problem:
http://forums.ni.com/t5/Multifunction-DAQ/How-to-get-rid-of-the-periodical-spikes-on-the-sinwave-vol...
Greetings from Germany
Henrik
LV since v3.1
(3,556 Views)
