Having trouble acquiring analog samples faster than 50khz
I have a NI-6115 DAQ and am using the included ANSI C example to continuously acquire a voltage signal.  I am reading samples from a single analog input.   The only modifications I have made to the included example are to bump up the sampling rate (tried 2MHz, but only could get 50kHz) and the number of samples to read at a time(have tried between 1-10X the sampling rate).  I need to sample at around 2MHz, but thus far I have only been able to acquire samples at 50kHz, with a 1M value buffer size).
Any ideas?
J Klein
(3,023 Views)
Hey Klein,
It should work I tried running it on my computer and it works fine.  Try this code:
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int32 CVICALLBACK EveryNCallback(TaskHandle taskHandle, int32 everyNsamplesEventType, uInt32 nSamples, void *callbackData);
int32 CVICALLBACK DoneCallback(TaskHandle taskHandle, int32 status, void *callbackData);
int main(void)
int32 error=0;
TaskHandle taskHandle=0;
char errBuff[2048]={'\0'};
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,
"",2000000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,100000));
DAQmxErrChk (DAQmxRegisterEveryNSamplesEvent(taskHandle,DAQmx_Val_Acquired_Into_Buffer,100000,0,EveryNCallback,NULL));
DAQmxErrChk (DAQmxRegisterDoneEvent(taskHandle,0,DoneCallback,NULL));
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
printf(
"Acquiring samples continuously. Press Enter to interrupt\n");
getchar();
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
printf("DAQmx Error: %s\n",errBuff);printf(
"End of program, press Enter key to quit\n");
getchar();
return 0;
void *callbackData)
int32 error=0;
char errBuff[2048]={'\0'}; static int totalRead=0;
int32 read=0;
float64 data[100000];
// DAQmx Read Code
DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,100000,10.0,DAQmx_Val_GroupByScanNumber,data,10000,&read,NULL));
if( read>0 ) {printf("Acquired %d samples. Total %d\r",read,totalRead+=read);
fflush(stdout);
Error:
if( DAQmxFailed(error) ) {
// DAQmx Stop Code
printf(
return 0;
void *callbackData)
int32 error=0;
// Check to see if an error stopped the task.
DAQmxErrChk (status);
Error:
printf(
return 0;
Also what error message you are getting. May be you are not reading fast enough or the data buffer you set may be too small.
Good Luck
-lab
(2,996 Views)
Thanks for the reply!  I'll give this a shot and get back to you if things don't work out.
(2,976 Views)
