High and low limits for AI in DAQmx
What I just posted is the same as my first response.
Message 11 of 15
(1,708 Views)
it's not.  you didn't mention to do a comparison.  you wanted to return the clipped value of the max/min value, which is not what i wanted.
Message 12 of 15
(1,705 Views)
The comparison is the greater than or equal that I mentioned. Sorry, it was my second response. And, if you do exceed the limits, it will be clipped.
Message 13 of 15
(1,698 Views)
no problem. thanks for your advice.  now i have a new problem - when i create a new global task, i cannot remove it.  i.e. if i name a task as AI 0 and assign it to ai0, i cannot change or remove the task name.  It will always in the drop down list of global MAX channels.
Message 14 of 15
(1,695 Views)
Sorry, I don't use global channels. Are you trying to delete it in MAX? I don't see why you shouldn't be able to delete it.
Message 15 of 15
(1,693 Views)
