I recently bouth a Pci-6013 board with a ribbon cable and the CB 68Lp pin connector in substitution of my old Lab-pc1200 (i don´t need the analog output as i´m driving relays). I installed it with no problem, but when i startet the MAX explorer and opened the test pannel for my surprise i realized i was reading a noise (i supose, as i haven´t connectet any signal yet to the analog input) of about one volt, and some tiemes, as i start the test pannel i can get to read -3volts. Thats way away from maching my needs (my input signal comes from a the UB502 preamplifier from Behringer that gives a 1V signal more or less). I would apreciate any hinch on wether the board is deficient and i have to turn it back,or what could be happening. I a
sume that this is´t the correct working behavior of the board, that has a maximun imput signal of 10v, and 1v noise gives a very disappointing SNR.
I also would like to know wether i can get real time with this board in the 350ms order using a multitask operational system like the windows XP (i bealive that the program, with the normal daq boards, is run by the computer processor, and by now it´s not possible the adquisition of a new board).
Thank you very much for your help.
