High voltage compactdaq module
Does anyone know of a third party provider of high voltage modules (greater than 115 rms) for compactdaq?  Thanks.
(3,944 Views)
Hi dkotlow-
You may be able to find third-party C Series-based modules that support this type of measurement, but you will not be able to plug them into NI CompactDAQ.  Support for compatible NI CompactDAQ modules must be specifically added to NI-DAQmx, so there is unfortunately no third-party or custom module support at this time.
Can you please let us know a bit more about your application?  There may be another platform or measurement method that would work.
Hopefully this helps-
Tom W
(3,928 Views)
Hi Tom,
I need to measure solenoid voltages that are 115 VAC rms.  Trying to keep the system small so I opted for the ComapctDAQ config.
Thanks.
Dominik
(3,911 Views)
NI recently released a new module for CompactDAQ and CompactRIO that can measure up to 300 Vrms.  The NI 9225.  50kS/s/ch, 3 channels, 300 Vrms range.
I know this message is old....but I still get updates about messages from threads way older than '07.
have a good day,
Brett
(3,687 Views)
