Higher current output from NI 6008
I want to use the analog output of a 6008 to control a proportional solenoid valve that draws approximately 400mA and requires a 0 to 5 VDC signal. I thought I had seen such a circuit before on the NI site, but I can not locate it. How can I accomplish this control scheme?
Tim
Message 1 of 13
(4,462 Views)
Tim
optocoupler,scr, transistor,fet, driver/ relay combo....
Message 2 of 13
(4,457 Views)
Thanks.  A driver/relay combo isn't much help on an analog circuit though.
Does anyone perhaps know where I can find a schematic of something that has been tested and actually works? It has been too many years since I dealt with the design side.
Message 3 of 13
(4,444 Views)
Also the ubiquitous ULN2xxx series (2003) in this case, it even includes the protection diode:
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00001244.pdf
-AK2DM
Message 4 of 13
(4,443 Views)
The 6008 DAQ has digital outputs too.
-AK2DM
Message 5 of 13
(4,441 Views)
I have used the ULN2803 in numerous digital control systems but it doesn't have an analog output.
Tim
Message 6 of 13
(4,440 Views)
0 through 5V......use the AO of the daq to control a variable power supply or serial/usb/gpib out to it...
Message 7 of 13
(4,438 Views)
Ah, missed the proportional portion of the post.
Don't they typically use PWM to modulate the coil current/voltage, I have never used them in practice.
Or maybe an anlaog output driving a MOSFET?
-AK2DM
Message 8 of 13
(4,427 Views)
An adjustable voltage regulator such as the LM317 could work. You need to add a protection diode.  The AO voltage would be set to 1.25 V higher than the desired solenoid coil voltage and would be connected to the adjust terminal.  The power supply to the regulator needs to be greater than 8 V.
I have used these regulators as speed controls for small motors. They work well for moderate performance systems such as this will be.
Lynn
Message 9 of 13
(4,423 Views)
'Mr." Lynn:
Didn't think of that approach for the proportional solenoid.
Scary you mentioned the 317 for motor control, yes they do work quite well! Here is the one I designed for a couple applications.
-AK2DM
Message 10 of 13
(4,419 Views)
