How am I communicate the instructment using PCI-6260 with shield cable by labview?
I got question how to communicate instrument such as voltmeter using PCI-6250 with shield cable by labview?
Can anyone tell me? cause I am not using serial or paralle port. the labview express manual did not taught me.
peter
(2,854 Views)
Your question does not make much sense. The PCI-6250 is a data acquisition board with analog inputs and some digital I/O. It is not designed to control a voltmeter if by control you mean command a meter to, for example, set a range and take a reading. If the meter has a serial port connection, you connect a serial cable between it and the pc. If it has a GPIB connection, you buy a GPIB controller and connect the controller to the meter. What exactly is the make and model of the meter you're trying to control?
(2,849 Views)
