07-17-2008 09:36 AM
07-18-2008
03:40 PM
- last edited on
10-23-2025
03:47 PM
by
Content Cleaner
Hi Jeff,
Thanks for posting your concern. There is lots of good information about this issue. I would recommend this article as a good place to get background information about settling time. As for ways to minimize the errors due to settling time, I can think of two ways to go. The first is to reduce the impedance on each channel. This article explains how this can be accomplished. The second method is extending the amount of time between each conversion. This article explains how the convert clock is determined in the driver and how this value can be manually set. Hopefully this information is sufficient for your needs. Let me know if you have any other questions.
Kent
