How can I add extra analog outputs on the BNC-2090A?
My daq card is PCI-6289 which has 4 analog outputs.  I need to use 3 of them, but my breakout box BNC-2090A only has 2 analog outputs.  How can I reconfigure the box to give me an extra analog output?
(3,183 Views)
Hi Boomy,
Your PCI-6289 does have four analog out channels; however, only two are on each connector.  You will only have access to the two analog output channels for the connector your BNC-2090A is connected to, see figure 1-3 of the BNC-2090A manual.  If you do not need BNC connections and have an extra SHC68-68 cable then you can use something like the CB68LP and use hardwire.  Otherwise, you will need another BNC-2090A.
h_baker
(3,160 Views)
