How can I connect them?
This is the system and I dont know excatly, which cables, or other devices need I, how can i connect the DAQ with the perrure relief and the amplifier. I am new in this field. I attached the amplifier and the pressure relief data sheet. THank you!
(4,471 Views)
I chose ad device, because there is no analog output of NI 6221, i willl chose other device, but the question is real.
(4,468 Views)
The USB-6210 does not have any analog outputs.  So you cannot control your pressure relief with this DAQ board.
I suggest you give your local NI representative a call.  You can sit down with them and go through your requirements and they can point you in the right direction.
(4,467 Views)
Yes, i know, i wrote it. Anybody can tell me the answer? thanks
(4,459 Views)
NI 6221 is a PCI card. Do you mean N USB-6221? It has AO and AI. You could use NI USB-6211. It has 16 x AI and 2 x AO channels
Also you are trying to connect a 0-20mA to an amplifier. I guess you need current to voltage converter instead.
(4,420 Views)
