How can I control pneumatic actuators with DAQ-NI with QuickBasic?
I have to modify an existing application, written in QuickBasic, with which I want to control two Watson Smith electric-pneumatic actuators (to be controlled) and acquire signals from various (displacements and pressure) transducers. The DAQ in by National Instruments. The application should work in DOS, I assume (or also on Windows?). How/is this compatible? Is there a book/manual I can refer? I can handle the language, but I have no idea on the syntax, procedures, furhter hardwares needed to 'control' devices. Thank you!!
Message 1 of 8
(3,851 Views)
Can you rephrase your question? How exactly is your hardware setup and what kind of software are you using? And, what OS do you want to work this on?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 8
(3,838 Views)
The hardware has not been setup yet.
This is the sketch. The three pressure circuits will be supplied by a compressor of 7 bar.
Two of them will then be controlled by the Watson Smith actuators.
The last circuit will be operated manually and measured by a pressure transducer.
The application is a home-made one, written in Quickbasic and designed for 'Datascan' as a datalogger.
The new datalogger (?) is from NI.
Here is a list of the ones which we have:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/202545 http://sine.ni.com/nips/cds/view/p/lang/en/nid/203423 http://sine.ni.com/nips/cds/view/p/lang/en/nid/202571 http://sine.ni.com/nips/cds/view/p/lang/en/nid/202570
It seems that I need to buy this other (among NI products) for controlling the equipments:
https://www.ni.com/en-us/shop/model/ni-9263.html
I have no experience at all on how to communicate with devices; this is probably the reason why I cannot be clearer.
I would know how to do operations, print, plot on screen or on file, but not how to do the same with devices external to the pc.
I assume there are (at least) special keywords to locate the channels..?
Thank you,
Sonia
Message 3 of 8
(3,830 Views)
I forgot:
other three LVDTs should be acquired by the DAQ and read by the aplication.
Cheers,
Sonia
Message 4 of 8
(3,829 Views)
You might want to provide some information that is not on a site that requires a login and password.
And if you are using new NI hardware, why would you want to use something as old as Quickbasic and DOS. I don't think you even have support for that with any of the current NI DAQ products.
Message 5 of 8
(3,820 Views)
Obvious: because I am forced to use Ni DAQ products, which in turn seem to force to use Labview.
I still prefer 'written' languages, although 'old' (maybe like me), better than graphical ones.
Why new products are not made compatible with existing intruments?
Besides, could I run my Quickbasic application with Eclipse, which works in Windows?
I am attaching some DAQ files I downloaded.
Cheers
Sonia
Message 6 of 8
(3,817 Views)
You won't be able to interface with DAQmx (the driver used to communicate with NI-DAQ devices) directly. You will need to write an application in a supported environment (like C++, C, LabVIEW etc), create a DLL and then, possibly, interface with that DLL. So, the answer to your question is to use a supported environment to create the application, and then, interface with that application in QuickBasic, if that's possible.
Adnan Zafar
Message 7 of 8
(3,809 Views)
Thank you, Adnan.
I will try this way.
Cheers
Sonia
Message 8 of 8
(3,782 Views)
