How can I display the acquired data on the screen while logging it into the hard disk?
Hello every one,
I'm using LV 8.5 under windows XP OS, and my DAQ board is PCIe-6251 m-series board. I'm doing data acquisition at 1M/s, and after I stop acquiring, the data stored in the buffer will be writtien into the hard disk. Now I also want to display the input data (which are images of a high-speed camera) while acquiring, can I imeplement that? I don't want to slow down the acquisition rate.
I thought maybe I can use 2 queues to store the data, and write 1 queue into a file, and display the other queue. But the display would cost very fewer frames. If one frame contains 4096 pixels (4096 data), then can I skip in the queue so that it displays continuous 4096 pixels every 10K data?
Just to make it clear, assume the data in the queue is like oooooooooooooooooooooooo..., the elements I want to display are like xxxxooooooooxxxxoooooooo... in which 'x' is the element I want to display. Can I implement that in the queue? Or is there some other manner I can display without affecting the writting? Thank you.
Bo
My blog Let's LabVIEW.
Message 1 of 12
(4,140 Views)
No promises here, just some thoughts.
At 1 M/sec you'll need to be a little careful with your memory handling.  If you send your array straight from your DAQmx Read into a queue with no other branches, LabVIEW is smart enough not to copy the 1 M/s of samples.  It lets the queue own the memory pointer.  Then when your File Writing code performs a de-queue, once again LV won't need to do a memory copy of all the array elements.
However, if you want to send any of the data elsewhere such as a live user display, there *will* be some data copying going on.  You'll benefit from a good strategy on this.  Others may provide better or more proven ideas, but meanwhile here's what *I'd* do:
I would let the File Writing code take a subset of the data it pulls from the queue and send it out for use by the User Display code.  I would use a Notifier rather than a Queue for this, as it probably isn't crucial if the live display misses an occasional frame.  This approach allows the data acq to collect and enqueue at the max rate you need.  If this data copying bogs things down occasionally, the Queue just buffers data for a while until the File Writing code can start catching up.  The data acq won't be slowed down.
-Kevin P.
Message 2 of 12
(4,136 Views)
Hi Kevin,
Thank you for your reply. I'm not clear about one thing in your reply. It is a good suggestion to use the notifier to display the samples, but did you mean to use the data 'after' it is written? Or copy the data 'before' it is written? As I understand, you suggest to copy the the subset of the data before it is written into the file, but the 'selecting' will cost time (cpu and ram), is that correct? Thank you again.
Best wishes
Bo
Message 3 of 12
(4,120 Views)
I don't know the definitive answer, but I'd start by sending the data *after* it has been written to file.  There may be a way to structure the code to give LV enough hints that it won't ever have to make an actual data copy that way.   From reading other threads, I've come to understand that doing an array subset operation does not necessarily result in data copying.
So if the file write is done and *then* a subset of the written array is passed to a Notifier, LV may likely realize that the Notifier can now simply take over ownership of the original chunk of memory rather than making a copy of the contents.  I suspect (but am not at all sure) that if you branched the data off to a Notifer *before* the file write, a data copy would need to happen.
Attached is a screenshot to illustrate the kind of hint I have in mind.  Putting the notification inside a single-frame-sequence structure helps tell LV that the write must complete execution before performing the array subset and notification.  That should be enough hint that it can give owenership of the array to the Notifier.
-Kevin P.
Message Edited by Kevin Price on 07-18-2008 11:54 AM
Message 4 of 12
(4,111 Views)
Notifiers always make a data copy at the Send Notification node. The reason is that you can obtain a notifier and then ask to get the latest notification even after it occured, so it needs to exist somewhere. I don't have the specific reference on me, but it should be in one of Stephen's posts on LAVA.
A queue does reuse the buffer because the data can only be dequeued in one place, so you would want to use a queue here.
___________________
Try to take over the world!
Message 5 of 12
(4,093 Views)
Correction, the copy is done at the Wait primitive (which is essentially the same thing, because the only way you're not going to get a copy is if you don't handle the notification at all). Here's Stephen's post.
___________________
Message 6 of 12
(4,083 Views)
Thanks for the correction, tst.  Yeah, it *does* make sense -- if you were to loop over Wait On Notification with "ignore previous" = True, you'd *expect* to keep retrieving the same stale data.
I think it'd still be my preferred option though, since the data copy would be confined within the GUI chart update code.  If I had decided I could live with lossy notifications, I could very likely also live with a little extra lag in the display.   There are other kinds of apps that would be better served by using queues.
-Kevin P.
Message 7 of 12
(4,071 Views)
Thank Kevin and tst, I'll think about your great suggestion. Your words are kind of hard for me, and it will take some time for me to fully understand it.
Best wishes
Bo
Message 8 of 12
(4,062 Views)
Hi Kevin,
I followed your suggestion and used the notification to display the array subset. If the subset will copy the data in any case, then I don't need to add a single-frame sequence for that, is that correct? And another problem is, I want to display some subsets of the array but not just one, for it's a long array and the displaying didn't update fast enough. Do you know how I can do that? Thank you for your reply.
Best wishes
Bo
Message 9 of 12
(4,047 Views)
Sorry, I edited my post, but it didn't work. The reason the displaying didn't update fast is it happened after the dequeue, so I put it before the queue right after the DAQ. I used a branch of the acquired data, and I'm testing if it slow down the acquisition.
Cheers,
Bo
Message 10 of 12
(4,045 Views)
