How can I download the NI DAQ Videos ?
I want to order a USB 6008 Interface.
Now I've found the videos at http://www.ni.com/dataacquisition/d/nidaqmx.htm that explain how to use the USB 6008 with VisualBasic, VB .NET and so on. How can I download the videos ? Are they on youtube oder somewhere else ?
Are also other languages supported like Java ?
(2,907 Views)
Hi Hans,
unfortunately the Webcast and Videos cannot be downloaded. For what concerns Java, it is not officially supported but  feasible since NI provides a Java Interface for National Instruments Drivers. however, my suggestion would be to use either LabVIEW or one of the .NET languages (Visual Basic, C++ or C#) to program. With both LabVIEW and .NET, you will have full access to the DAQmx libraries, example programs, and much better NI support. Here are some links to get you started doing DAQ with Java.
http://digital.ni.com/public.nsf/websearch/802A9D349090D3F5862565CC0076BCF9?OpenDocument
http://forums.ni.com/ni/board/message?board.id=250&message.id=20386&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=250&message.id=2236&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=250&message.id=863&requireLogin=False
Best regards.
Andrea Perin
Application Enginner
(2,892 Views)
