How can I enable 5v output of USB-6009?
I use USB-6009 with Simulink.
But I couldn't get 5v power from device.
Is there any condition or command to enable this 5v power output?
(3,564 Views)
Hi Hyon Lim
Thanks for your post. I have a couple of ideas and questions so I can figure out why your not getting an output of 5V.
What type of load (if any) do you have connected to the digital output lines and the +5V line?  If the load draws too much current from either/any of the lines then the output logic level will start to drop below 5V. Are you using the device in push-pull (3.3V) or open collector (5V) mode?  Also, do you have the load connected when the device is powered up?
Try measuring your +5 V pin on your analog input line. What voltage do you read out?
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
(3,494 Views)
