How can I find out how to successfully modify a rtsi triggered square wave on my 5411 using labview 4.1
The attached vi was edited out of a larger program written in Labview 4.1. I tried running it with no errors, however I was not able to generate the sawtooth waveform if selecting "waveform 0". I checked the outputs from the 5411.
(2,804 Views)
Hi Jeff,
If you check the system requirements of the 5411, you'll see that you require LabVIEW version 6.1 or later.
With the updated version of LabVIEW, you'll be able to download the NI-FGEN driver to control your ARB.
Signal Sources Drivers
Andrew
(2,792 Views)
