How can I generate a continuous analog output signal using ni usb 6008
I don't manage to generate a sine analog ouput using labview with NI usb 6008.  It tells me "error code 200077", but i paid attention to avoid a too fast signal (f=1hz and sampling=100hz), or too high (Vmin=1V, Vmax=3V).
Does the USB-6008 supports continuous analog output generation, and  if yes, how to proceed further ?
(3,295 Views)
Your error can be explained in this following link:
http://digital.ni.com/public.nsf/allkb/4387AD95E8D6EDB186256FE20063B1BA
Unfortunately, USB 6008 has limitation on signal generation since it only has software time which only gives update rate up to 150 samples/secon. You may refer to this below link:
http://digital.ni.com/public.nsf/allkb/6F2C2B49A89D685C8625711D007BDD64
Cheers,
 Yasrof
(3,285 Views)
Thanks a lot Yasrof. my problem is solved now.
Cheers
Nicolas
(3,257 Views)
