Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How can I get the 1 MHz function to light up in a timed loop?
MC_Nanotechnolo
gist
Member
08-20-2008
04:23 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have a PCI-6251 DAQ card and I want to run a loop faster than 1 kHz. When I put a timed loop in it will only let me select 1 kHz, although I see that there is a 1 MHz option that is grayed out. What would allow me to use 1 MHz?
0
Kudos
Message
1
of 2
(2,901 Views)
Reply
Re: How can I get the 1 MHz function to light up in a timed loop?
Wayne.C
Trusted Enthusiast
08-21-2008
07:09 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
1 MHz is only available when the vi is targeted to a RealTime target such as a cFP, cRIO or PXI. You also need the RealTime Module for LV.
0
Kudos
Message
2
of 2
(2,887 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
