How can I measure a linear position with NI USB-6210 and inductive sensor??? How is connection or schematic? Thanks
Is possible to acquire a linear position from inductive sensor (BAWM08EI UAD15B BP03) with NI USB-6210??? How is connection or schematic? Thanks
(3,092 Views)
Hi de_mayo,
If you can provide some more information regarding the sensor you're using, like the manual, then I should be able to help you out more. That being said, I don't see why you wouldn't be able to use the inductive sensor in question with the 6210. You just need to figure out the connection configuration which is something that should be provided for in the manual of the inductive sensor.
Paul
National Instruments | Applications Engineer | www.ni.com/support
(3,073 Views)
Try a Google of your sensor part #, you will get lots of listings for the Balluf sensor of that number, complete with specs and wiring diagram. You will need a separate15 - 24 vdc power supply for the sensor. The signal output range will match ok with the analog input to your DAQ, but you might want to put a crowbar zener across the anaolg input, so that if your sensor fails and dumps the dc power supply across the DAQ input, the crobar will limit the volatage to the DAQ.
Good luck
(3,043 Views)
