02-24-2004 09:53 AM
02-25-2004
11:16 AM
- last edited on
11-10-2025
11:37 AM
by
Content Cleaner
Hi Paul
You say that you have tried all three grounding methods. Does one method provide cleaner signals than any other method? Usually differential mode will provide better noise rejection on your analog input channels since they would not be sharing a ground with the counter.
Do you get the same noise levels in MAX as you do with LabVIEW?
Here is a link that may help with some of your noise issues.
Let me know if you have any other questions.
Russell G.
Applications Engineering
