How can I syncronize two PCI-5102 scope cards with immediate trigger?
I have two PCI-5102 scope cards in my system and have successfully synchronized the two cards to produce four synchronized waveforms on a graph in my application.
I followed the NI 5102 synchronization topic in the NI High-Speed Digitizers Help which basically sets one of the scope cards as a master device which exports it's StopTriggerEvent over the RTSI bus to the other scope as a slave device with it's trigger set to digital trigger from the exported signal from the master.
This works very well with the master's trigger set to an edge trigger but how can I syncronize my two PCI-5102 scope cards with an Immediate trigger?
If I set the master trigger to Immediate it does not seem to export the trigger event to the slave.
Message 1 of 1
(2,836 Views)
